No problem Jeff, although I should thank you for solving that one for me.
Hey, since I have your attention. 🙂 You wouldn't happen to have a thought
or solution to my question in Land Desktop Customization titled Get LDD
Point Number in Map would ya?? Have a good one!
John Michalik
Drafting and Design
LDD/CAD Development & Standards
johnm@weissereng.com
"Jeff Mishler" wrote in message
news:412bae3f_2@newsprd01...
> Yep, that's the one! Thanks, John.
> And here's the text from my original post (2/5/04):
> Just use the appload command to load it, then, at the Command: prompt,
> type "label_tan_pi" to run. If you already have an alignment set
> current, it just labels it. If not, it prompts to select one. I did not
> incorporate the LDD alignement select process (select on screen, type,
> or select from a list), only selecting on screen works, so if you want
> to pick from a list, use the LDD align select first.
> Hoping you like it,
> Jeff
> Jeff
> check out www.cadvault.com
> "John Michalik" wrote in message
> news:412ba735_1@newsprd01...
> > Jeff,
> > I believe it was this one? I think you were the one who had helped me
out
> > with the same problem, so I'll pass the help on!
> > John Michalik
> > Drafting and Design
> > news:412b9fe7_3@newsprd01...
> > > I posted to either this newsgroup or the Land customization group a
lisp
> > > routine that will label all PI's of the current alignment. I don't
seem
> to
> > > have it on this computer so i can't post it again until I find it. A
> > search
> > > of those groups should locate it for you though.
> > > Jeff
> > > "Robert Ruiz" wrote in message
> > > news:412B6B9E.EC444E11@hogancorp.com...
> > > > Hey does anybody know how to make pi labels appear when you do
station
> > > > labels on alignments? I have an alignment that is made with a
polyline
> > > > with no curves.
> > > > When I station them, it does not label the bends with a pi station.
> > > > Any help would br great.
> > > > RR
