Oceanside are you sure the "current" status of the Points>Points Settings,
Insert tab, Insertion Elevation portion of the Dialog Box isn't set to a
Fixed Elevation of zero, instead of the Actual Elevation?
I always use the Actual Elevation, with a setting of -13.00 for the "If No
Elevation Use:" just above the Fixed Elevation BTW, but that's just me. ;0)
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5562962@discussion.autodesk.com...
After rotating points, checking points, modifying project & drawing, I no
longer show an elevation for the civil point object when selected. I'm
getting a "0" elevation where before rotation I got the elevation (points
inserted by "actual elevation"). Point List looks good. I updated the
point group and rebuilt my surface. I closed and reopened project. What
am I missing?
