I haven't ACTUALLY died from the error. It just forks that error, but when
you reopen the drawing (in Land) it will place the ADCADD_ZZ block on one of
the other layout tabs. The only harm I've ever seen is that some of the
drawing setup "stuff" gets hacked up.
Brent Jorgensen
"Justin Sousa @ Omsberg & Company" wrote in message
news:5F5B7A588C8A32151AA1FA9769BD86F6@in.WebX.maYIadrTaRb...
> That sounds familiar somehow, isn't there a lisp routine someone created
> that would basically fix the block on the first (only) layout tab?
> Justin Sousa - jsousa@omsberg.com
> "Jon Golubiewski [Autodesk support]"
> wrote in message
> news:8CFF1A69D07E883AC4725108FCA17602@in.WebX.maYIadrTaRb...
> > If that's the case, inserting this drawing into a new drawing should
take
> > care of it (the map query should work too).
> > The ADCADD_ZZ block is an invisible block at 0,0 on the first layout
tab.
> > So, by creating a new drawing in Land Desktop, the ADCADD_ZZ block is
> > recreated. When you insert the new drawing, the old block is a
duplicate
> > and left behind
> > Jonathan Golubiewski
> > Autodesk Professional Services
> > Land.Civil.Survey
> > "Brent Jorgensen" wrote in message
> > news:5D8B7A0E05117B28F5E6C33D18C02A85@in.WebX.maYIadrTaRb...
> > > I've had this occur after deleting layout tabs, and (I think) have
> > narrowed
> > > it down to this: If I delete the layout tab with the ADCADD_ZZ block
on
> > it,
> > > it gives this error. Otherwise, just fine.
message
> > > news:0987562A7670BACD4B94616E2F509782@in.WebX.maYIadrTaRb...
> > > > I have discovered that this problem actually begins after deleting
> > layout
> > > > tabs and purging (all). Is this related to the old "fixnump nil"
> error?
> > > > AecCCogo.arx: Exception in AecAppCogo::saveDwg()
> > > > Omsberg & Company (707) 443-8651
> > > > Surveyors - Planners - Engineers
> > > > visit our website at
> > > > www.omsberg.com
> message
> > > > news:12F6A9D9503C9733B0D0564C8E254078@in.WebX.maYIadrTaRb...
> > > > > Recently a few of my dwgs started giving me this error when i
qsave:
> > > > > I found a previous post on this subject and the only reply was to
> > > install
> > > > > service pack 2 (for Land Desktop 3) I have done this and the error
> > > > persists.
> > > > > Ideas anyone?
> > > > > Thanks,
> > > > > Omsberg & Company
