• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    xrefs cause lag in object selection
    125 Views, 2 Replies
    05-22-2012 11:27 AM
    I am working on a drawings with nested xrefs and am experiencing major delays when selecting objects using crossing windows. It is as if the computer thinks I am selelecting the xref even though the curser doesn't touch any visible exref entities. Basically, I click to start the window and the curser freezes for 10 to 20 seconds. I am experiencing the same problem with other commands (intermittenly) such as move, line, and offset. The exrefs are on a separate locked layer and have been moved to the back of the drawing. Does anyone have an explanation for this or a solution?
    Please use plain text.
    pendean
    Re: xrefs cause lag in object selection
    05-22-2012 03:00 PM in reply to: s.geddes
    How many Xrefs in total?
    PC specs? Windows OS?
    LT version?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Mentor
    AcadAdamLT
    05-23-2012 03:58 AM in reply to: s.geddes
    Are you absolutely sure it's the Xref's that are causing the lag? if not, try to unload all of them. If you don't have any more lag after that try reloading them one at a time to see if it's all xref's or just one of them. Or maybe it's just too many xref's and your computer can't handle them all.
    Signature, sincerely... //Adam
    AutoCad LT 2014
