• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    unhandled exception error C0000005 (Access Violation Reading 0x0144)
    687 Views, 4 Replies
    01-14-2013 01:44 PM
    HI i just intall autocad lt 2013 and everytime i poen the program it gives me the "unhandled exception error C0000005 (Access Violation Reading 0x0144) at adress 60c6f5bfh" now i already uninstall all the other autodesk programs and reinstall this one for second time now and i still get the same error. i try the repair but it still doesnt work; if i try to "save as" the program stops working. i can save but i dont know where is sending the file  and it also stops working if i try to close it.
    thank you
    Please use plain text.
    Charles_Shade
    Re: unhandled exception error C0000005 (Access Violation Reading 0x0144)
    01-14-2013 02:02 PM in reply to: banji1234
    Restore the Computer to several days ago and prior to the first install.
    Follw this advice from Autodesk to see if there are any stragglers in the Registry:
    Autodesk Recommended Clean Install Procedure:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
    Try the install again.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Contributor
    04-05-2013 12:32 AM in reply to: banji1234
    I have similar problem, and I've clear installed my software (AutoCAD LT 2012) and problem still exist. What shall I do now?
    Distinguished Mentor
    braudpat
    04-05-2013 05:38 AM in reply to: ABielecki
    Hello
    You try to install ACAD LT 2012 32 bits or 64 bits ?
    On which Windows exactly ?
    Before, have you some others Autodesk software running OK ?
    If YES, which one ?
    Bye, Pat
    Charles_Shade
    04-07-2013 05:09 AM in reply to: ABielecki
    You may want to get into removing and reinstalling the current .NET that is on your system as well.
    REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
    Use this as the uninstall instead of Windows.
    Then reinstall the AutoCAD after you have done the previous suggestions to this program as well
    Remember to back up your customizations first.
