• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Accepted Solution
    text scale for template
    172 Views, 7 Replies
    10-09-2012 07:29 PM
    I am trying to set up my template for architectural drawings.  I would like to use annotative text and dimensions and leaders.  I have selected a font and am trying to set my Paper Space text height to 3/32" so all drawings in all scales have text of 3/32".  When I type in 3/32" it returns a value of 1/8".  How do I get it to recognize the 3/32" value. Also if I save this in the dwt file will it always be set for this?
    ag
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: text scale for template
    10-10-2012 05:01 AM in reply to: alex.gotthelf
    Go to UNITS and change the Precision value to 1/32 instead of 1/8.
    2. Yes
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    10-10-2012 06:16 AM in reply to: Charles_Shade
    accept solution. One problem though; my text for leaders says 3/32" but it comes out 1/8". When I double click on the text box it shows 6" (at 1/4" scale) not 4 1/2" as it should.
    ag
    *Expert Elite*
    Charles_Shade
    10-10-2012 06:35 AM in reply to: alex.gotthelf
    Are you using MLEADER or QLEADER?
    From the Dropdown; Format; MLeader or fromt he Command line: MLEADERSTYLE make sure the text height is set to 4-1/2".
    If you have defined a height for this Text in the Textstyle manager this box will be grayed out.
    (check the box on the bottom right of the post :smileywink:)
    10-10-2012 06:48 AM in reply to: Charles_Shade
    Thanks. I am using MText or MLeader. I tried qleader and it came out the right size. I'm not sure why you use one over the other. The mleader seems to be the default and there is only a Block or None option in the styles. The grayed out box says 3/32". Should this be set to zero in the text style?
    ag
    *Expert Elite*
    pendean
    10-10-2012 08:12 AM in reply to: alex.gotthelf
    Post a DWG file with the problem MLEADER in it, add instructions inside the fil to shwo what you want vs. what you got.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    10-12-2012 07:42 AM in reply to: pendean
    Accept as solution
    ag
    *Expert Elite*
    Charles_Shade
    10-12-2012 09:46 AM in reply to: alex.gotthelf
    On the bottom right of each post in the Thread is a place to select the Mark as Solution.
    Doing this step will allow the post to show how it was Solved and will provide the telltale Green Check.
