• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    setting up
    34 Views, 2 Replies
    08-16-2001 03:16 AM
    I just started using LT2002 today, and I am trying to setup my taskbars etc as I like. I am having two problems:
    1) I am trying to change the object snap settings in the Tools/Drafting Settings/Object Snap box. When I press Okay, it gives me ERROR: Unable to set system variable: SNAPUNIT. Why?
    2) Then under Views/Toolbars/Commands, some of the icons are not shown. It says "Close Window is there, and I can drag the button onto the taskbar and it works, but there is no picture associated with the command. How am I supposed to remember where I put which command?
    Any help would be appreciated.
    kedibeno
    Please use plain text.
    *Saadallah, Dean
    setting up
    12-13-2003 09:54 PM in reply to: kedibeno
    1) Set SNAPUNIT, or SNAP to something other than the 0 setting
    you have, and all will work well again. I know, nothing to do with it ....
    2) Not all commands have a toolbar button image, so you need
    to make one: right click on the button, and go for it. HELP in AutoCAD can
    explain usage.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    kedibeno
    New Member
    Re: setting up
    Thanks Dean - Both worked.
    kedibeno
