• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    paste issues again!!
    335 Views, 10 Replies
    11-16-2012 07:34 AM
    I got an issue with paste command again!!
    I am working on a drawing with 20 pages, I have to copy some texts in all drawings and I did it for 19 pages but suddenly I can not paste it in last page!!
    And surprising that I can not paste anything in the drawing anymore!
    I have tried to paste with clipboard but doesn't work!
    even I copy from other drawing, Can't paste it!
    this is the error that I'm getting:   " Substituting [simplex.shx] for [MSURVEY.SHX] "
    even I reload this file it doesn't work :smileysad:
    Please use plain text.
    Charles_Shade
    Re: paste issues again!!
    11-16-2012 08:15 AM in reply to: EL-Designer
    Do you have the MSURVEY.SHX Font?
    Assuming you do but if not you need that SHX Font or change the Textstyle that uses it to one that you have.
    BTW - I did have a SHX font become corrupt the week or two ago. Never did find out why.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    11-16-2012 01:13 PM in reply to: Charles_Shade
    how can I fix corupted SHX file?
    pendean
    11-16-2012 01:25 PM in reply to: EL-Designer
    20 pages: as in 20 different DWG files, or 20 layouts (or 20 locations in one modelspace)?
    What is clear is this one "file" you cannot paste into, perhaps the layer is frozen or it is a file from another source with AEC content in it? I seriously doubt an SHX corruption is the problem.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Charles_Shade
    11-19-2012 05:11 AM in reply to: pendean
    Offered that as a reason why the OP's file may no longer be recognizing the SHX font.
    Isn't a SHX issue something that another poster had a couple weeks ago when trying to paste into a drawing?
    It was missing therefore the paste would not finish?
    11-19-2012 07:14 AM in reply to: pendean
    It Is one drawing with 20 layouts, there is no frozen layer!
    I van not past anything!! its so wierd :smileysad:
    Charles_Shade
    11-19-2012 07:40 AM in reply to: EL-Designer
    Ran AUDIT on the file?
    Tried WBLOCK to a new file?
    11-19-2012 12:42 PM in reply to: Charles_Shade
    I audited the drawing, still doesn't work.
    I made a block from the objects that I wanted to copy when I want to paste it, I can see it on the clipboard but when I click on the page something else will pasted that I have no Idea where that come from?!!
    pendean
    11-20-2012 04:48 AM in reply to: EL-Designer
    so the problem is one single file? Post it here, remove any sensitive info first. Share your font too, use ETRANSMIT command to package a ZIP file to post and inlcude everything needed with the file.
    11-20-2012 05:59 AM in reply to: pendean
    I opened the drawing today and it works fine!!
    I have no idea what happened !
    but please let me know if someone found a solution!
