• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    mtext reformatting
    91 Views, 3 Replies
    04-26-2012 04:55 PM
    mtext notes in my drawings occasionally reformat when I reopen a file.  The notes become a column of single words.  I have to go to each note and stretch the box.  Doesn't always happen, but when it does every mtext box becomes a column.  I'm using LT 2012.
    Please use plain text.
    pendean
    Re: mtext reformatting
    04-27-2012 05:24 AM in reply to: glbsnb
    You turned on and left on the Column setting in MTEXT: while in MTEXT, right-click, select COLUMNS then NO COLUMNS.
    Take the time to always ensure that is set like that, and your Mtext issues will go away.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    04-27-2012 07:40 AM in reply to: glbsnb
    Thanks.  How do I set the default to No Columns in the future?
    pendean
    04-27-2012 07:42 AM in reply to: glbsnb
    AFAIK setting it once keeps it that way until you change it.
    For existing Mtext objects, PROPERTIES will let you change it to None too.
