• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    isolate layers won't unisolate
    1554 Views, 11 Replies
    01-02-2009 09:13 PM
    When I isolate a layer or turn off a layer from the icon command, it works. When I hit the icon for "turn on all layers" to get back, the layers that were isolated or turned off remain ghosted and the work I did is lost since I have to hit undue to get all my layers back on...? This was not a problem in AutoCAD 2000 I used for years before getiing LT 2008.
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: isolate layers won't unisolate
    01-03-2009 05:52 AM in reply to: rogerleonard
    Try the LAYUNISO command or the Layer Unisolate button. And check out Help under "isolating layers". Has this been a constant or a recent problem?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Dean Saadallah
    01-03-2009 10:11 AM in reply to: rogerleonard
    You would rather UNDO and lose all your work than
    simply turn on the layers using LAYER command? Really? Was that the only
    solution you spotted, undo??? That's a self-inflicted problem.
    REGEN may have been able to refresh your screen and
    turn on those layers: you have have frozen instead turned off layers too, or
    frozen layers inside viewports. Get into LAYER command and see what is
    actually happening and why.
    And stay away from UNDO as the solution for Pete's
    Sake.
    Member
    01-03-2009 04:47 PM in reply to: rogerleonard
    Thanks.
    1) LAYUNISO doesn't work. This is a constant problem.
    2) TURN ALL LAYERS ON icon does not restore the ISOLATE LAYERS ghosted layers.
    3) REGEN doen't work.
    What does work, now that I tried it, is : LAYER STATES MGR icon ... then hit RESTORE.
    It would seem TURN ALL LAYERS ON should restore and unisolate the work as in 2000.
    I appreciate the comments.
    Roger
    Member
    01-03-2009 04:48 PM in reply to: rogerleonard
    Thanks.
    I appreciate the comments and the sarcasm is funny too.
    Roger
    *Dean Saadallah
    01-03-2009 07:44 PM in reply to: rogerleonard
    Your original post lists two commands to 'hide' a
    layer, and two commands to 'unhide': these are two separate functions and from
    your description of your final fix I suspect you may be mixing and matching. Not
    a good idea.
    *Expert Elite*
    Charles_Shade
    01-04-2009 06:35 AM in reply to: rogerleonard
    Sounds like you have a bad install, a CUI conflict, or some other conflicting program - registry problem.
    Member
    01-04-2009 09:03 AM in reply to: rogerleonard
    I agree. Now trying to have AutoCAD respond (or even finding a place to converse with them) is the problem.
    Thanks!
    Roger
    *Expert Elite*
    Charles_Shade
    01-04-2009 11:52 AM in reply to: rogerleonard
    Try here: (yes, it is buried)
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7031104&linkID=9240817
    Installation and registry cleaners can generally be solved here in this discussion if you want to persue further. You may even want to post the macro for your LAYUNISO from your CUI to make sure it has not gotten hosed up somehow.
    Member
    01-04-2009 12:41 PM in reply to: rogerleonard
    Thank you very much.
    I'll try the Help phone call first.
    Roger
