• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Member
    AJAMP
    dwg compare plug-in
    446 Views, 5 Replies
    11-15-2012 09:51 AM
    I was told that I should download and install DWG compage plug-in to compare 2 dwg files.  I have downloaded the file and installed it (at least I got the "successfully installed" message) but when I open AutoCAD LT 2013 it does not show up on the plug-ins tab and using the dwgcompare command returns an "unknown command" response.  Am I missing something in the initialization of this plug-in?
    Mark
    Please use plain text.
    Charles_Shade
    Re: dwg compare plug-in
    11-15-2012 12:07 PM in reply to: AJAMP
    What is the link to this plug-in?
    AutoCAD LT is not TurboCAD Pro.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    DarrenP
    11-15-2012 12:16 PM in reply to: Charles_Shade
    i am assuming its the one from the exchange app store which doesn't work with lt only with full blown autocad and  the verticals
    http://apps.exchange.autodesk.com/ACD/Detail/Index?id=appstore.exchange.autodesk.com%3adwgcompare%3a...
    Active Member
    AJAMP
    11-15-2012 12:38 PM in reply to: DarrenP
    This is the link I was given.
    http://apps.exchange.autodesk.com/ACD/2013/en/Detail/Index?id=appstore.exchange.autodesk.com%3adwgco...
    We are using AutoCAD LT 2013 and I need to compare and combine edits that were made to the same file by 2 different editors 'simultaneously'.
    Mark
    Charles_Shade
    11-15-2012 01:02 PM in reply to: AJAMP
    On the right side there is a matrix that shows what this App is compatible with.
    AutoCAD LT is not mentioned here.
    pendean
    11-16-2012 04:43 AM in reply to: AJAMP
    No such tool exists for LT: sorry.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
