AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
copy and paste jpg in dwg
- Highlight
- Email to a Friend
I have autocad lt 2009, previosly when I wanted to trace a drawing I would go to paint, copy the drawing and then paste it in autocad on one layer and do the drawing on another layer worked great, But now when I do the same process it doesnt work.....previously I could draw on the image, could edit the lines, copy, erase, move etc. But now when do this if I have to copy a line I select copy and when I click on the line I want to copy the jpg drawing goes away, or if I try to erase a line the drawing will get deleted, Do I need to uninstall autocad and reinstall? Like I said it worked out fine before but now it is messed up. Sorry this is so long but didnt know of a shorter way. Thanks
Re: copy and paste jpg in dwg
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
To set draw order, select the image and type in DRAWORDER then hit the ENTER key, it comes up with 4 options select the one that gives the desired effect. (Above, Behind, Front, Back)
To set the frame, type in FRAME then hit the ENTER key, enter erther 0, 1, 2, or 3
0 The frame is not visible and it is not plotted.The frame temporarily reappears during selection preview or object selection.
1 Displays and plots the frame.
2 Displays but does not plot the frame.
3 The individual setting varies for all objects with frames in
All this info was found in the help menu
Regards Lawson
If any answer solves your problem, remember to mark it as solved
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
If it solved your problem you should mark it as "Accepted solution" so that others can see the thread is finished.
/Adam
AutoCad LT 2014
