• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    bak files are not being created
    116 Views, 8 Replies
    03-12-2013 11:05 AM
    autocad is not saving backup files automatically, only when i manually save are they updated [defeating the purpose of them].  in my options - open and save - i have my automatic saves set to 3 minutes and am also set to create backup copy with each save.
    please help.
    thanks
    Please use plain text.
    Active Member
    Re: bak files are not being created
    03-12-2013 12:24 PM in reply to: theresaramsay
    *Expert Elite*
    pendean
    03-12-2013 02:21 PM in reply to: theresaramsay
    You relying on autosave to create BAK files? You pretty much have to give up saving and risk losing everything for that to happen.
    Say it isn't so... .
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    03-12-2013 02:30 PM in reply to: Holly_Jones
    thanks for that!  i do see some files there.  still wondering why the bak file in the file i'm working on does not update unless i manually save?
    Member
    03-12-2013 02:32 PM in reply to: pendean
    thanks for your reply but i'm not sure what mean? i'm wondering why my backup files aren't backing up unless i save my drawing - which is useless.
    *Expert Elite*
    pendean
    03-12-2013 02:46 PM in reply to: theresaramsay
    Autosave in AutoCAD doesn't work like Autosave in MSWord: it's best practice to never rely on it and to get in the habit of manually saving regularly. It's best relied on in case of a crash/recovery type scenario only.
    Member
    03-12-2013 02:53 PM in reply to: theresaramsay
    i try to save as often as i remember, however i can go an hour without saving and then when my autocad crashes and i try to retrieve my backup file and it hasn't be updated since my last save or worse the previous day - it's frustrating.  i have worked on many autocad setups before this version / computer and never had this problem.  my coworkers also don't have this problem but can't help. i thought perhaps someone could show be how to fix this issue.
    thanks for trying.
    *Expert Elite*
    Charles_Shade
    03-12-2013 06:56 PM in reply to: theresaramsay
    Many here have added the Save command to oft used OOTB Commands and custom Macros.
    Helps to create that Save without thinking about it.
    3 Minutes may be too quick. Try 10 and see if you get better results; though with the Sage advice that has been given, it is better to Save early and often.
    Also a SAVE or QSAVE wil reset the backup clock so it is possible to not create a backup during a CAD session.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Expert Elite*
    pendean
    03-13-2013 05:31 AM in reply to: theresaramsay
    After a crash, you need to go to your system temp folder and look for SV$ files with the same name as your DWG file: check the time to ensure it's later than your DWG file, rename the extension, and 95% of the time you will recover more content than a BAK file after a crash.
