• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    ron.white
    angle option in LT2013 array command--
    158 Views, 1 Replies
    10-08-2012 06:25 AM
    If you miss the angle option in the array comand in LT2013--tech support sent me this info--
    "The angle options is removed from command line
    option. However, after creation please hover the bottom right grip and select
    Axis Angle and specify the angle by picking a point. If you want to enter angle
    value please turn off the dynamic input and enter the angle value in the
    command line. "
    Please use plain text.
    pendean
    Re: angle option in LT2013 array command--
    10-08-2012 09:10 AM in reply to: ron.white
    Thanks for sharing. If you get a chance, tag your own post as the solution here so others can find it.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
