aligned dimension text size different
alex_gotthelf
alex_gotthelf
I am using annotative dimensions and when I use normal dimensions the text comes out correct at 3/32" but when I use aligned dimensions the text height is 1/8".  How do I fix this?
ag
pendean
Community Legend
Community Legend
Same exact DIMSTYLE with no overrides? Not possible: post a DWG portion with the problem if you want additional review of the issue.
alex_gotthelf
here is the file.  I am printing from model space right now.
ag
pendean
Community Legend
Community Legend
Your DIMSTYLE behaves as it should, regardless of angle, all the text is the specified height.
However, your currently drawn dimensions and text are not correct for the posted annotative scale (1/64"): so I turned on ANNOAUTOSCALE, set the annotative scale to 1:1 then back to 1/64"=1'-0" and they all bounced back to the correct size.
alex_gotthelf
Thank you.  The ANNOAUTOSCALE was set to -4 on my drawing.  I reset it to be 1 and did what you said and yes the dimensions resized to the correct size.  So should I change my template to be 1?
ag
pendean
Community Legend
Community Legend
I keep mine set to 4 all the time (it's a system setting, not per file I believe).
