AutoCAD LT
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Viewport anomaly - help please
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello fellow autocad associates.
I have multiple viewports in one layout. They do not overlap because I initially created them as polygons, converted into regions, subtracted from each other, then converted into viewports. So everything is nice and orderly.
All my layers are thawed, unlocked.
After working on a different layout and then closing and reopening the file, the first viewport created (the largest one) has gone rogue. It's borders seem to be the size of the entire layout, overlapping the other viewports. I cannot delete it as it's borders are no visible, hence I also cannot select it. But it is a nucience because it is overtop of my other viewports meaning it is the default when I pan in model space!
I hope I don't have to delete this layout and start again. Has anyone come across this before?!
Re: Viewport anomaly - help please
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
All layers are on and visible, and all layers are thawed. I have regenerated and audited both in model and layout space.
Still the view remains without any borders.
I wonder if it has anything to do with making my original polygon into a region and then creating a viewport from that region?? If so, how do I edit this invisible region?
When I get to work I will post a screen shot to show what is going on...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try doing this. First select the good viewports and move them to a new layer and freeze that layer then open the properties window and issue QSELECT. In the object type flyout select region (If you originally used a region to convert it to a viewport it should still be there) hit OK to dismiss the window. Now you can see it's properties in the properies window or just delete it or delete the whole viewport by slecting viewport in the QSELECT window.
There used to be a thread on this forum describing a similar problem. The viewport was a clipped viewport and the user miraculously managed to remove the clipping boundary which made the viewport border invisible.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, replied to the wrong person.
