• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    Accepted Solution
    Upgrade problems
    119 Views, 4 Replies
    04-27-2012 07:09 AM
    I know, I'm crazy but not only have I upgraded to Autocad LT 2013 but I changed my computer at the same time! I seem to have everything sorted except for plot style tables - I can't find them. Does anyone know where they live?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Upgrade problems
    04-27-2012 07:41 AM in reply to: mhomer
    Probably still on the old computer where you left them?
    Otherwise elaborate, is this just a STB vs CTB issue?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    04-27-2012 08:04 AM in reply to: mhomer
    Its a ctb issue. You're right I know where they are on the old computer, what I don't know is where I should copy them to on the new one.
    *Expert Elite*
    pendean
    04-27-2012 08:13 AM in reply to: mhomer
    In AutoCAD, any version, start PLOTTERMANAGER command and that folder opens right away. Copy them there.
    A DWG file is either STB or CTB set, to switch it between them use CONVERTPSTYLES command.
    Member
    04-30-2012 08:19 AM in reply to: mhomer
    Thank you, problem solved.
    MH
