• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    Upgrade from LT 2010 to LT 2013
    299 Views, 4 Replies
    10-12-2012 07:52 AM
    I just installed my upgrade, and I noticed that 2010 is still present as a application (And opens as LT 2010). Is it alright if I uninstall this? Or is it required to run my 2013 upgrade.
    Please use plain text.
    Charles_Shade
    Re: Upgrade from LT 2010 to LT 2013
    10-12-2012 09:48 AM in reply to: datruscott
    You may uninstall the LT 2010
    Make sure you have your Customizations before you do so.
    If you run a Registry Cleaner after the uninstall you may strip some components of the 2013 install by accident so be wary.
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Member
    10-23-2012 08:00 PM in reply to: datruscott
    I wish to upgrade from AutoCAD LT 2010 to AutoCAD LT 2013 as well. I own a full AutoCAD LT 2010 license, and I just purchased a new AutoCAD LT 2013 Upgrade license.
    However my machine (a Dell/AlienWare Aurora desktop) has just been re-imaged, so all AutoCAD software has been removed/cleaned. I'm not exactly sure how to go about this installation properly.
    Do I install AutoCAD LT 2010 first, then install AutoCAD LT 2013 Upgrade?
    I've scoured through the web-site and can't seem to locate any specifics in regards to this specific scenario.
    I appreciate your help here.
    pendean
    10-24-2012 04:58 AM in reply to: BryantRacing
    You don't need to install the old software first: but you do need the old serial number to install the 'upgrade' version.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    10-24-2012 10:58 AM in reply to: pendean
    thanks I will procede forward installing the new AutoCAD LT 2013 Upgrade package.
