• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Units Autocad LT / Unités Autocad LT
    370 Views, 10 Replies
    04-18-2011 01:34 AM
    I have a problem : my autocad LT 2010 has configured an non-identified unit : when I ask a 2000,100 (millimeters) rectangle, the result is a 2740,440 (millimeters) rectangle... I'd like to be in a metrical system, and my config parameters are scale : 1:1 and unit : millimeters... I didn't have this problem yesterday and don't know what happened... Please Could you help me (in a débutant english or french please) ?
    Rrrady
    Bonjour,
    J'ai un soucis avec mes unités sur Aotocad LT 2010 : si je demande un rectangle de 2000 mm par 100, le rectangle obtenu mesure 2740 par 440 mm. Je voudrais revenir à mon système métrique qui marchait encore hier. Dans Outils -> Options, je suis sensée bien être en millimetres avec une échelle de 1:1...
    Pourriez-vous m'aider s'il vous plait?
    Merci beaucoup
    Rrrady
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Units Autocad LT / Unités Autocad LT
    04-18-2011 05:27 AM in reply to: Rrradassse
    Start a new file.
    Recreate the problem, can you?
    If not, post that new DWG file here for someone to review.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    04-18-2011 06:21 AM in reply to: pendean
    with new files, the problem is similar and I noticed that  the size of my 2000,100 rectangles is aleatory :  I tried a new file (acadiso.dwt), and made 3 rectangles, size : 1000,100 : 1st in withe, 2nd in red and 3rd in yellow...
    Do you have an idea of what kind of problem it is and how to resolve ti?
    *Expert Elite*
    pendean
    04-18-2011 08:02 AM in reply to: Rrradassse
    Post a DWG, not an image.
    04-18-2011 08:25 AM in reply to: Rrradassse
    Here is joined a new file for exemple. I made 3 rectangles on, same size  : 1000,100.
    But I don't think that the files are the problem... for me it's a software problem... isn't it?
    Thank you for your attention, I'll be back tomorrow (in France it's evening)
    Rrrady
    *Expert Elite*
    pendean
    04-18-2011 10:46 AM in reply to: Rrradassse
    Your file does not contain any 1000x100 rectangles: see attached.
    Do you just need to turn off your running OSnaps when drawing them?
    04-19-2011 12:28 AM in reply to: pendean
    Please, what is a "OSnaps"? I am not computer's specialist and doesn't speak very well English...
    I turned off and turned on my computer, but same things with Autocad LT...
    *Expert Elite*
    Charles_Shade
    04-19-2011 04:28 AM in reply to: Rrradassse
    OSNAP is an AutoCAD Command. Type OSNAP at the Command line to see the options.
    Dean is wondering if your Line is just snapping (connecting) to points in your Modelspace environment.
    Check the Snap and Grid tab and see if Snap On (F9) is unchecked.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    04-19-2011 04:37 AM in reply to: Charles_Shade
    "Commande inconnue "OSNAP".  Appuyez sur F1 pour obtenir de l'aide." -> OSNAP is not a known Autocad LT command..., but I verified that I hav'nt any grid or grid hanging.
    I tried F9 on, and F9 off. There is no consequenses on my rectangles...
    May I didn't understand your advices?
    *Expert Elite*
    Bob_Zurunkle
    04-19-2011 10:16 AM in reply to: Rrradassse
    F9 is the snap spacing, which less and less people use these days.
    F3 is Object Snap -- when you draw a line for example, it will snap to the endpoint of another line if that's how your OSNAP is set up...
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
