• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    aanspach
    Unable to Update AutoCAD LT 2010
    409 Views, 2 Replies
    10-22-2010 11:16 AM
    My AutoCAD LT has been randomly crashing.  It used to be quite often when I would use the measure tool, overwhelm it with too many tasks (hitting buttons too fast) or hitting esc when it was performing a task.  This morning it crashed while using the copy tool and again with the move tool 20 min later.  When I sent the error report, it showed that I need the Update 2.  I attempted to download the update and install it.  It asked for the disk but then said the information on the disk wasn’t available.  It continued to give a 1603 Error Code.  Our IT suggested to uninstall and then reinstall the software but I was concerned with reregistering the serial number even though it is on the same computer.  How can I fix this problem?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Unable to Update AutoCAD LT 2010
    10-22-2010 12:03 PM in reply to: aanspach
    Does your CD driver work?
    Did you use an LT2010 CD? is there more than one disk?
    1603 Error Code:
    http://usa.autodesk.com/adsk/servlet/ps/search?la=en&siteID=123112&catID=2334116&linkID=9240817&qt=1...
    Autodesk recommended uninstall and reinstall procedures:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
    Folks uninstall and reinstall regularly with no issues about reauthorizing legal licenses.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    New Member
    aanspach
    10-25-2010 04:20 AM in reply to: aanspach
    Yes, my CD driver is working.  It is able to open the CD, but isn't able to find what is looking for on it.  it is looking for a .msi file but when I click on it, it goes back to not finding the appropriate content.
    Yes I was using the ACAD LT disk and there is only one disk available.
    I plan to uninstall and reload today.
