R14 is a translation process: if your file contain AEC content it can take
what seems to be a very long time to complete.
First, try to PURGE your files and AUDIT or RECOVER them too. Delete all
Layer Filters as well. As a text, try R12DXF too. Also consider WBLOCK as a
file management option too.
If you installed an Object Enabler, most likely you have content in your
file that you cannot distinguish from stock entities, and you may not be
able to take it down to R14. You will need to be in the specialized version
of AutoCAD to complete the task.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
