• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    Recover dwg 'file not valid'
    235 Views, 6 Replies
    03-13-2013 07:49 AM
    I'm using AutoCAD 2012 LT and have just had a fatal error message.  AutoCAD asked me if I want to save a recovery file which I agreed to, obviously.  Now that I'm trying to recover the file, titled <FILENAME>-recover.dwg, its telling me that the drawing file is not valid.  The BAK files are older than the recovery file, as is the originally saved file.  I want to open the most recent, recovery file, but can't... Any ideas?!
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: Recover dwg 'file not valid'
    03-13-2013 07:52 AM in reply to: CJPmha
    It was posited earlier to look in your Temp file for SV$ files and see if these are more recent.
    Search SV$ if the Temp folder is not readily apparent.
    Have you tried to just use Recover from the big red A menu?
    And what size is the file that you are trying to open? It may not be viable.
    Temp File location can be found under OPTIONS; Files tab:
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    New Member
    03-13-2013 08:01 AM in reply to: Charles_Shade
    Looking at explorer, the recovery file (which I can't open) is 11.6MB whereas the original file was about 6MB.  I haven't done much to it between these files to justify that much of a hike...
    The recovery manager (through the big red A) won't open it either.
    The SV$ file doesn't exist, even though I've got my autosaves and backups switched on.
    We have just upgraded to 2012 from 2009, and it worked perfectly well then, I know because the pcs suffered fatal errors quite regularly, which is the reason for the upgrade in the first place - AutoCAD just got upgraded with it.
    *Expert Elite*
    03-13-2013 09:40 AM in reply to: CJPmha
    I have had this happen to me several times.  The recovery file generated can’t be opened.  I found that at that point there was little that I could do.  BAK files are always older than the DWG file they are backing up.  Since it seems there is no SV$ I think that all you can do is open the DWG file and redo your work.  This happens regardless of the release of software.  It's unfortunate.  To help remedy situations like this I tend to save (by pressing CTRL+S) every few minutes.  It's a habit that I have gotten into and has saved me several times.  Also check your auto save settings.  Bump up the save time interval.  Make it ten or maybe even five minutes.  The problem with that though is that it may interrupt your work to execute the save.  I find it annoying when it does which is why I manually save the files myself so often.
    I know this doesn't help your current situation and I wish I could help there.  I wanted to share my experiences with you demonstrating how I deal with this constant issue.
    Brian C. Benton
    bbenton@cad-a-blog.com
    http://CAD-a-Blog.com
    twitter.com/bcbenton
    facebook: www.facebook.com/CADaBlog
    skype: benton.brian
    *Expert Elite*
    Charles_Shade
    03-13-2013 09:58 AM in reply to: CJPmha
    Try posting the file here. Maybe someone else can give it a go opening it.
    The smaller 6meg one
    New Member
    04-06-2013 10:06 AM in reply to: CJPmha
    i am unable to open this file please any body can open this file and send it to me as soon as possibe i am very thankful please repair this drawing and send me on this mail famaan2@yahoo.com
    *Expert Elite*
    Charles_Shade
    04-07-2013 05:16 AM in reply to: famaan
    The file is dead and at 219 KB is pretty small. There may not be any valid information in it.
    Do you have a BAK copy of this file?
