• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Quick Properties Box Transparency
    66 Views, 1 Replies
    11-05-2009 08:20 AM
    Autocad 2010LT. I don't want it off, but a lot of times it gets in the way. I've been able to set the transparency on other items but have not found a way to do it with the quick properties box. Can it be done.
    Please use plain text.
    *Dean Saadallah
    Re: Quick Properties Box Transparency
    11-05-2009 08:50 AM in reply to: cjwagner
    If it was available, it would be set the same way as others. Minimize it's
    visible 'idle' rows instead (DSETTINGS command) by using the auto-collapse
    feature better.
    IMHO, having it on all the time defeats it's best feature: setting it to
    pop-up when needed WHERE you need it (QPLOCATION variable).
    Dean Saadallah
    http://LTisACAD.blogspot.com
