• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    FLHX
    Accepted Solution
    Question About Autosnap
    96 Views, 3 Replies
    05-01-2012 01:35 PM
    I have the magnet setting OFF, and the Object Snap ON.
    I draw a line, then when I add a second line, it automatically starts at an ENDPOINT, never at a MIDPOINT.
    I can turn Object Snap OFF, and it stops, but I really need  to start lines at the nearest OSnap, not just the nearest ENDPOINT.
    Just curious, since this is new, is there a different setting besides these two I'm using??
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: Question About Autosnap
    05-01-2012 02:30 PM in reply to: FLHX
    I assume that you have MIDpoint checked on?
    What is your OSMODE Variable set to?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Expert Elite*
    pendean
    05-01-2012 03:51 PM in reply to: FLHX
    If you want it to always start at the MIDPOINT, youo need to only have the MIDPOINT object snap set (or actively type it).
    OR
    If you are going to have many other Osnaps set at the same time, them you need to ensure you are always near the osnap you want (midpoint of the line) and not nearest another osnap (endpoint based on your post) for it to work.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Contributor
    FLHX
    05-02-2012 04:34 AM in reply to: FLHX
    It was 4133.
    I changed it to 16383, and I'm all set.
    As usual, Thanks a million!
