• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    jlane
    Plots not matching .ctb for one LT user
    168 Views, 3 Replies
    05-23-2012 08:51 AM
    We have two drafting assistants using LT 2010, with Windows XP.  One is assigned to do record plotting, and uses our company standard .ctb file without any problems.
    The second LT 2010 user has now been assigned to assist with record plotting.  However, lineweights are plotting out about half the width of the specified .ctb file.  We have double-checked all the ACAD LT & Windows plot settings, and they are identical for both drafting assistants.
    I've seen similar problems posted in the discussion group, but none of the conditions seemed to match what we are experiencing.
    Is there a system variable or other setting that I am missing?
    Thanks!
    __________________________
    jlane
    Inventor RS 2011
    AutoCAD Mechanical 2011
    ASD 2013
    Vault Collaboration 2011
    Windows 7 Pro
    Please use plain text.
    pendean
    Re: Plots not matching .ctb for one LT user
    05-23-2012 06:33 PM in reply to: jlane
    unless they use the exact single centrally located CTB file the problem may be that you have two of them.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Product Support
    Albert_Rius
    05-29-2012 07:07 AM in reply to: jlane
    Can you check also if  the .pc3 files used are identical?
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Albert Rius
    Support Specialist
    Product Support
    Active Contributor
    jlane
    05-29-2012 07:33 AM in reply to: Albert_Rius
    Hi Albert,
    We aren't using .pc3 files. We simply select the plotter that we want the dwg sent to.  Today we tried plotting, and the linetypes plotted out as they should - according to our .ctb file.
    I'm assuming that rebooting took care of the problem (?)
    Thanks anyway.
    jlane
    Inventor RS 2011
    ASD 2013
    Windows 7 Pro
