• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    Re: Plot to PDF-some letters are faded
    10-17-2012 01:26 PM in reply to: btrydel
    Same problem as Btrydel, faided text and object no real rhyme or reason. Im using publish in Acad 2013 but the problem has been an issue since at least 2010. Creating and plotting are fine, the problem is viewing in Adobe viewer
    Please use plain text.
    Charles_Shade
    10-17-2012 01:40 PM in reply to: breierg
    Then the PDF works fine and you need to figure out where your monitor and graphics card are giving you the issue.
    For me Adobe looked very nice but Foxit is not as attractive on screen. The opposite of what Dean posted I believe.
    32" Sharp Aquos thru HDMI connection
    1366 x 768 @ 60 Hz
    NVIDIA GeForce GTX 560 with DVI output
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Member
    btrydel
    10-17-2012 02:35 PM in reply to: Charles_Shade
    The PDF that I create using "DWG to PDF.pc3" as the plotter selection comes out readable but not presentable to a client, even at 100% zoom.  Once created, the image looks bad on any machine/monitor that I send it to.  Other PDF programs work fine, and so does AutoCad LT 2008 with "DWG to PDF.pc3" selection.  Just having trouble with 2012 version.
