• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    Accepted Solution
    Object Enablers for 2012
    350 Views, 8 Replies
    05-26-2011 09:56 AM
    Any word on when LT will have object enablers  available to diplay the ACAD Arch & ACAD MEP objects?
    The ACAD Civil is the only one posted.
    ****Sage
    Re: Object Enablers for 2012
    05-26-2011 09:58 AM in reply to: RAMasterson
    Those that know cannot say, and those that say do not know :smileyhappy:
    LT2011's OEs came out late for some reason if that's any help.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Employee
    05-26-2011 03:02 PM in reply to: RAMasterson
    OE's for Architecture & MEP objects are built in to the product now. But if you have a file that's not displaying properly, please send it to me (kate.morrical@autodesk.com).
    Kate Morrical
    Technical Marketing Manager
    Autodesk, Inc.
    LT Unlimited
    AutoCAD Insider
    Valued Contributor
    05-27-2011 05:19 AM in reply to: Kate_LT
    Thanks for that info Kate...Do you know if this is also true for DWG TrueView 2012?
    New Member
    cdgoin
    11-04-2011 10:37 AM in reply to: RAMasterson
    Well Im running ACAD 2012 and ACAD MEP objects from my Electrical Contractor (Done in MEP) are showing as simple AEC Proxy blocks.. "yea".. maybe an enabler wouldnt be a bad idea.. just in case.
    New Member
    at.lawrence
    12-11-2011 02:58 AM in reply to: Kate_LT
    Kate,
    Here is a file that is displaying fairly ok, but I get a dialog box asking for proxy graphic information.  It was created in AutoCAD 2012.  I just want the dialog box to stop popping up every time I open the file.
    Your help will be greatly appreciated.
    A. Lawrence
    ****Sage
    12-12-2011 04:53 AM in reply to: at.lawrence
    Set PROXYNOTICE to 0 (off): look all these "proxy" commands and variables up in HELP, they all start with the word PROXY.
    Dean Saadallah
    New Member
    at.lawrence
    12-13-2011 02:08 AM in reply to: RAMasterson
    Thanks Dean.
    I have another question: How do I set up a pen settings file?
    Regards.
    Anthony
    ****Sage
    12-13-2011 04:34 AM in reply to: at.lawrence
    PLOT STYLE TABLES? start with one of the free one provided to ensure it has the "color" output you want, then make a copy of it with STYLESMANAGER, give it a unique name, then edit the linewieghts and test until you are satisfied with the results.
    Dean Saadallah
