• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Member
    OSNAP not applying to xrefs
    64 Views, 3 Replies
    08-02-2005 12:50 PM
    When i try and snap to an object in an xref, the only snap tool that it reads is "nearest." Also, I can not use an xref line to trim something in the current drawing.
    Please use plain text.
    *Dean Saadallah
    Re: OSNAP not applying to xrefs
    08-02-2005 01:24 PM in reply to: happyjj
    Don't have NEArest osnap running, see if that helps.
    Or zoom in much tighter to the one you are aiming for... .
    I don't understand the second half of your post, can you
    clarify?
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    Active Member
    08-02-2005 02:18 PM in reply to: happyjj
    I don't know that i understand your reply. Nearest is the only osnap that works on the xref even when I have all of them selected. And I did try zooming in closer -- it didn't help.
    For the second item, if I select the trim tool, and then select a line from an xref as the cutting edge, the xref'd line will not cut the line that I'm trying to trim. Does that make any more sense?
    *Dean Saadallah
    08-02-2005 02:36 PM in reply to: happyjj
    AHHH! I thought you meant to had running Osnaps and only
    nearest showed up.
    You can ONLY use nearest on an xref.
    No, it's supposed to work. Set WHIPARC to zero, REGEN then
    try again. Should also solve your trim selection problem.
    This assumes your XREF is in the same Z-plane as all your
    other objects of course.
    Dean Saadallah
