• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    beksolar
    Mouse left click selecting multiple lines,objects not working
    836 Views, 6 Replies
    02-26-2012 02:59 PM
    Can not click on multiple objects or lines for erase,trim or extend commands. Is there a mode that I have turned on by accident , driver warning also comes up in trim offset command.
    Please use plain text.
    heinsite
    Re: Mouse left click selecting multiple lines,objects not working
    02-26-2012 05:04 PM in reply to: beksolar
    Check that PICKADD = 1 and see if that makes a difference.
    Dave.
    Dave Hein, P.E.
    New Member
    beksolar
    02-27-2012 02:47 AM in reply to: heinsite
    Thanks Dave that did it.
    Charles_Shade
    02-27-2012 04:57 AM in reply to: beksolar
    So that others may more readily find this solution to a similar query:
    Please mark any response as "Accept as Solution" if it answers your question.
    Kudos + gladly accepted if you are feeling magnanimous
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    02-27-2012 06:36 AM in reply to: Charles_Shade
    Hi Charles,
    I've had both PICKADD AND PICKFIRST change settings on me for no reason. Is this something that is fixed with SP1?
    We are waiting for our IT Dept. to "have time" to install it. :smileywink: We are using 2012LT.
    Thanks for any info.
    Charles_Shade
    02-27-2012 09:09 AM in reply to: sthompson1021
    No there is nothing that I know off that will change these at random; though anecdotally it does happen.
    Do you have any Custom Macros that you use for choosing items in a specific way?
    02-27-2012 09:22 AM in reply to: Charles_Shade
    No, I pretty much leave things alone other than the pgp file. I never had any problem with it untill we upgraded from 2011 to 2012. Since then it has happened twice with PICKADD  and once with PICKFIRST. All I can say is that I would have gone nuts if it wasn't for this forum. I don't know if I would have figured it out yet.
