• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    Accepted Solution
    Locating Origin in Model Space
    221 Views, 3 Replies
    09-18-2012 09:49 AM
    Hello!
    (ACAD LT 2012)
    I can't seem to locate the 0,0 (ORIGIN) in Model space.
    SCENARIO 1:
    I create a line > specify second pt to 0,0 > Enter = NADA
    SCENARIO 2:
    Create a Line > Select Line > Move to 0,0 = NADA
    HOWEVER, If i create something, use COPYBASE command, and and specify 0,0 --> PASTE into new drawing with 0,0 as insertion point, it can locate it... so it's there.... i just can't find it.
    Please help, thx!
    -- gxl
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Locating Origin in Model Space
    09-18-2012 10:22 AM in reply to: germXXL
    http://ltunlimited.typepad.com/my_weblog/2008/08/absolute-vs-rel.html
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11753684&linkID=9240815
    Be more specific when typing out coordinates in LT, that way you avoid odd settings in files:
    @x,y for relative
    #x,y for absolute
    See if that helps.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Member
    09-18-2012 10:58 AM in reply to: pendean
    Thank YOU, Dean!!
    This may sound lazy, but I do NOT want to type in #.
    I've never had to do this (being specific) before using other acad version.
    However, the first link you provided solved my problem -- once I found where Dynamic Input was located.
    step-by-step Solution:
    Selection Cycling (CTRL W)  >   RT CLK Settings > Dynamic Input > Settings for POINTER INPUT  > Select ABSOLUTE COORDINATES.
    Background Extras:
    I trried to move something to 0,0 (before solution):   FAIL
    Co-Worker #1 attempts same thing on her machine using same drawing:  SUCCESS
    Co-Worker #2 attempts same thing on her machine same drawing:  FAIL
    OPEN new drawing and attempt to locate 0,0:  FAIL
    Co-Woker #2 finds Survey from consultant.  Attempts to locate 0,0 using her machine:  SUCCESS (weird since she couldn't do it in the previous drawing)
    All 3 of us check our POINTER INPUT SETTINGS to see if it's a settings issue or drawing issue.  All of us have RELATIVE COORDINATES Selected.... (weird right?)
    *Expert Elite*
    pendean
    09-18-2012 11:03 AM in reply to: germXXL
    That's why I posted the links :smileyhappy:
