• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Distinguished Contributor
    KateMorrical
    Launch PDF Reader with AutoCAD LT
    241 Views, 7 Replies
    01-03-2013 02:27 PM
    There *is* a command you can use to launch PDF documents from a button in AutoCAD LT, isn't there? (I do mean "open", in Acrobat Reader or equivalent.)
    I know there used to be one, because I have macros that used START to open a PDF file. However, they were built for AutoCAD LT 2007, and START is not a known command in AutoCAD LT 2010.
    (This is embarassing for two reasons. First, I wrote the darn thing! Why can't I remember how I did it? And second...this icon should launch the CAD manual....and no one but me has noticed that it's broken. :smileysad:)
    Kate Morrical
    Digital Design Manager
    Washington, DC
    BIMmuse.com
    Please use plain text.
    Re: Launch PDF Reader with AutoCAD LT
    01-03-2013 05:13 PM in reply to: KateMorrical
    Does the ai_STARTAPP Command work for you?
    For example
    ^C^Cai_startapp;"c:/users/John/Documents/AOSRE50300[1].PDF"
    Don't forget to use / (slash) instead of \ (backslash) when specifying the path because as you know backslash is used for wait for user input in macros.
    pendean
    01-03-2013 05:22 PM in reply to: Johneng
    Missed it by 9-minutes :smileysad:
    _ai_startapp is what I use.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    KateMorrical
    01-04-2013 06:35 AM in reply to: Johneng
    Bingo! But was START ever a valid option? I've been trying to find out, but "START AutoCAD LT command" doesn't exactly generate good search results. :-) I seem to remember some sort of switch, but so much has happened between now and when I first wrote the macro that it might as well have been done by somebody else.
    Kate Morrical
    Washington, DC
    BIMmuse.com
    Charles_Shade
    01-04-2013 08:11 AM in reply to: KateMorrical
    An LT Unlimited tip; I believe, from a couple years ago:
    "Macro revisioning to newer platforms may require that ^R be added to the beginning of the Macro."
    (Tough this has nothing to do wih the needed Command. :smileywink:)
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    KateMorrical
    01-04-2013 10:16 AM in reply to: Charles_Shade
    Admittedly I didn't try that one. :-)
    Kate Morrical
    Washington, DC
    BIMmuse.com
    pendean
    01-04-2013 10:19 AM in reply to: KateMorrical
    Are you thinking of the START entry in the PGP file? LT OOTB has no entries for it but AutoCAD does.
    KateMorrical
    01-04-2013 10:49 AM in reply to: pendean
    Ah yes, entirely possible. At any rate it's close enough to put it in the "solved" category...thanks.
    Kate Morrical
    Washington, DC
    BIMmuse.com
