Launch PDF Reader with AutoCAD LT
KateMorricalTowne
Message 1 of 8
KateMorricalTowne
There *is* a command you can use to launch PDF documents from a button in AutoCAD LT, isn't there? (I do mean "open", in Acrobat Reader or equivalent.)
I know there used to be one, because I have macros that used START to open a PDF file. However, they were built for AutoCAD LT 2007, and START is not a known command in AutoCAD LT 2010.
(This is embarassing for two reasons. First, I wrote the darn thing! Why can't I remember how I did it? And second...this icon should launch the CAD manual....and no one but me has noticed that it's broken. Smiley Sad)
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
Replies (7)
Message 2 of 8
Johneng
Does the ai_STARTAPP Command work for you?
For example
^C^Cai_startapp;"c:/users/John/Documents/AOSRE50300[1].PDF"
Don't forget to use / (slash) instead of \ (backslash) when specifying the path because as you know backslash is used for wait for user input in macros.
Message 3 of 8
pendean
Community Legend
Community Legend
Missed it by 9-minutes 😞
_ai_startapp is what I use.
Message 4 of 8
KateMorricalTowne
Bingo! But was START ever a valid option? I've been trying to find out, but "START AutoCAD LT command" doesn't exactly generate good search results. 🙂 I seem to remember some sort of switch, but so much has happened between now and when I first wrote the macro that it might as well have been done by somebody else.
Kate Morrical
BIMmuse.com
Message 5 of 8
Charles_Shade
An LT Unlimited tip; I believe, from a couple years ago:
"Macro revisioning to newer platforms may require that ^R be added to the beginning of the Macro."
(Tough this has nothing to do wih the needed Command. Smiley Wink)
Message 6 of 8
KateMorricalTowne
Admittedly I didn't try that one. 🙂
Kate Morrical
BIMmuse.com
Message 7 of 8
pendean
Community Legend
Community Legend
Are you thinking of the START entry in the PGP file? LT OOTB has no entries for it but AutoCAD does.
Message 8 of 8
KateMorricalTowne
Ah yes, entirely possible. At any rate it's close enough to put it in the "solved" category...thanks.
Kate Morrical
BIMmuse.com
