• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    LT2007 can't open 2004 version?
    224 Views, 7 Replies
    07-08-2011 07:59 AM
    I've always believed that Autocad (including LT) can open a file saved in any previous version. That's been my experience and why I save files as a previous version when sending files to consultants. Is this not true for LT2007?
    Please use plain text.
    Charles_Shade
    Re: LT2007 can't open 2004 version?
    07-08-2011 09:38 AM in reply to: lostagain
    Is the program saving the file AutoCAD (full) or some other vertical?
    Only reason I can think is a Revit file or something similar not wanting to open in LT.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Valued Contributor
    07-08-2011 10:22 AM in reply to: Charles_Shade
    I am saving from regular Autocad 2011 to 2004. The recipient is using LT2007 and can' t open the file. The problem isn't that LT2007 can't read a standard Autocad 2004 version file - right? So I can narrow down what exactly is the problem. Thanks.
    Charles_Shade
    07-08-2011 11:21 AM in reply to: lostagain
    Proxy objects maybe?
    Any warnings pop up from the LT 2007 user when they try to open the file?
    Audited or Recovered the drawing prior to Saving?
    Your right that it does not make sense.
    I am in LT 2012 but post your file if you can so I can give it a go. Maybe someone here with LT 2007 will try too.
    pendean
    07-09-2011 04:32 AM in reply to: lostagain
    Why not save to 2007 format for the 2007 user?
    And have you tried AECTOACAD command as an alternative?
    How about ETRANSMIT?
    your method of file delivery?
    If the send you back the file, can you open it? (as opposed to only opening the file you have)
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    07-09-2011 02:54 PM in reply to: pendean
    All I'm asking at this point is whether my long held belief is correct that Autocad (LT or regular) can open any file saved in a previous version. It's not stated in the HELP, but it's been my experience and I posted here for confirmation.
    I appreciate the tips on additional troubleshooting, but I'm not at that point yet.
    pendean
    07-09-2011 09:03 PM in reply to: lostagain
    LT is AutoCAD: newer versions can open older version files, like 99.9% of all ther software.
    Valued Contributor
    07-10-2011 09:44 AM in reply to: pendean
    Thanks, Dean.
