• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Accepted Solution
    LT 2013 - Unhandled Exception
    357 Views, 6 Replies
    03-06-2013 11:33 AM
    Getting these type of errors - "Unhandled Exception 0 - (Access Violation Reading 0x0048) at address D1DE6773H" and "Unhandled Exception 1 - (Access Violation Reading 0xcfb2f590) at address D4A93914H"
    This happens everytime the program is exited on 3 different computers, the computers are new and are running Windows 7 - 64 Bit.
    Capture-2
    Please use plain text.
    *Expert Elite*
    pendean
    Re: LT 2013 - Unhandled Exception
    03-06-2013 01:44 PM in reply to: ACOVA
    This just started, or has always happened and today is "fix it" day?
    Or is there something new (PC, add-on, drivers, etc.) you forgot to mention?
    Looks like you installed the CIVIL Object Enabler for LT2013, correct? You could try removing it and reinstalling LT2013 (answer yes to replace all) and see if that helps.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    03-06-2013 02:09 PM in reply to: pendean
    This is something that has happened since day one (all 3 are new and configured the same) and just getting around to it since it doesn't affect production. That is correct regarding the Civil Object Enabler. I will try removing it and reinstalling LT. Thanks.
    *Expert Elite*
    pendean
    03-06-2013 03:08 PM in reply to: ACOVA
    Windows 7?
    Or Windows 8?
    Please ensure that LT2013 is fully patched and updated too.
    03-12-2013 07:39 AM in reply to: pendean
    Removing the Civil Object Enabler worked to get rid of the problem. The question now is what happens when I need it?
    *Expert Elite*
    Charles_Shade
    03-12-2013 06:50 PM in reply to: ACOVA
    Is the LT 2013 fully patched and updated prior to installing the OE?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    03-13-2013 07:31 AM in reply to: Charles_Shade
    Yes, and this only happened on computers running Windows 7. We have two other computers running Vista without a problem.
