• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    Accepted Solution
    LT 2012 slow after restarts and reboots
    166 Views, 3 Replies
    10-03-2012 08:45 AM
    Normally LT runs fast enough that you can't see what it's doing, but occasionally it will bog down so that you can see the lines in the Properties manager fill in one by one as you select and deselect entities.  A quick restart of the program used to be all it took to refresh it and get back to normal speed.  But I still have this problem after multiple restarts and a machine reboot.  It's slow enough to be almost unusable.
    It's an old machine due to be replaced but is usually fast enough.  I've got nothing else running, I even turned off the McAfee (usually the culprit on speed issues) and nothing is helping.  Is there anything else I can try before I have to kick a wall and reinstall LT?
    XP Pro SP3
    Intel Core2 6300
    1GB RAM
    Please use plain text.
    *Expert Elite*
    pendean
    Re: LT 2012 slow after restarts and reboots
    10-03-2012 08:50 AM in reply to: kwg06516
    Try a Windows Restore back to a time/day it all worked fine.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    10-03-2012 10:53 AM in reply to: pendean
    I guess I'll never know what was really causing it but thanks.
    *Expert Elite*
    Charles_Shade
    10-03-2012 12:10 PM in reply to: kwg06516
    I've had .NET updates cause issues in the past and the Restore cleared it up.
    Along with not installing the .NET update of course.
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
