• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    tbolt650cc
    I'm getting a Read-only message from a file sent by 3rd part
    124 Views, 10 Replies
    11-27-2012 11:32 AM
    When I try to open an AutoCAD LT file sent to me from an architect it opens with a message stating that it is read only. Can this be protected by the sending designer, or is this an issue on my side? I don't have a server, I'm on a stand alone PC (Windows). :smileyfrustrated:
    Please use plain text.
    pendean
    Re: I'm getting a Read-only message from a file sent by 3rd part
    11-27-2012 12:40 PM in reply to: tbolt650cc
    Are you placing the file on your harddrive in a folder then opening it (proper way), or are you opening it in the email message/application (gives you that error message)?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    tbolt650cc
    11-27-2012 12:52 PM in reply to: pendean
    I save it to a file on my desktop. Normally I import that file into my pre plotted sheet. When I import the drawing I will import it as a "Block"
    *Pro
    11-27-2012 01:04 PM in reply to: tbolt650cc
    right click on the file on your desktop and check the properties.  It's prolly marked read-only. Clear the check marks in the boxes for read-only and you should be good to go.
    DJ
    tbolt650cc
    11-27-2012 01:18 PM in reply to: drjohn
    The read only box was un-checked, now when I try to import that file as a block the command bar reads, "Invalid"
    *Pro
    11-27-2012 01:34 PM in reply to: tbolt650cc
    Might wanna try opening it alone with recover rather than importing it to see if it took a hit for some reason (transfer over inet or whatever).
    If that works, open the target file and INSERT it rather than an import.
    Charles_Shade
    11-27-2012 01:36 PM in reply to: tbolt650cc
    Open the Read Only file and Save it to a new name.
    (Delete the original and change the name of the newly saved file to the previous file name if you wish.)
    Does this now Open properly for you without warning?
    Semantics: INSERT is the Command to bring a Drawing File in as a Block.
    IMPORT is a different operation.
    Are yiu using INSERT?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    tbolt650cc
    11-27-2012 02:14 PM in reply to: Charles_Shade
    Okay, I tried inserting this per your suggestion. I continue to get an "Invalid" message in the command bar.
    tbolt650cc
    11-27-2012 02:18 PM in reply to: tbolt650cc
    ....and yes I did use the insert function not import. My apologies.
    Charles_Shade
    11-27-2012 02:23 PM in reply to: tbolt650cc
    The file opens normally?
    If not did you try a Recover per DJ's suggestion?
    Can you post the file here for others to try?
