• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD LT
    *Huffman, Chapman
    Fatal Error when Printing
    174 Views, 5 Replies
    12-13-2003 10:18 PM
    I'm getting a "FATAL ERROR - Unhandled float invalid operation exception at
    47a9e4h" whenever I try to print out of AutoCAD Lt98. I noticed this today
    when I added a plotter (HP 750C Plus) driver to my Windows 98 configuration.
    Now whenever I try to print to any printer (over a network to plotter, to a
    HP4000N laser, and a HP 4/4M laser) I get this weird message. I uninstalled
    the plotter from my system in hopes that it was ausing a problem but to no
    avail. I'd rather not uninstall LT98 and lose all my config settings (and
    it is an upgrade from Lt 95 to Lt97 to Lt98 which is a beast to reinstall).
    Everything worked fine printing to the HP4000N laser yesterday. Any ideas
    on possible culprits?
    Thanks!
    Chapman Huffman
    chiph@branchgroup.com
    Please use plain text.
    *Support], Keith Sibbert [Autodesk
    Re: Fatal Error when Printing
    12-13-2003 10:18 PM in reply to: *Huffman, Chapman
    Chapman,
    Try renaming the ACLT5.CFG file in the AutoCAD LT 98 folder to ACLT5.OLD.
    Keith Sibbert
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    > Thanks!
    > Chapman Huffman
    *Huffman, Chapman
    Re:
    Tried that and it looks like it reset the printer configurations. Only
    problem is now when I print to any printer I get the "Regenerating" bar
    (like normal) for about a second then another "FATAL ERROR - unhandled float
    invalid operation exception at 53f136h" and it bombs me out of the program.
    Think a reload of the LT98 upgrade will help any?
    Keith Sibbert [Autodesk Support] wrote in
    message news:3804FBF9.714C5B07@autodesk.com...
    > Chapman,
    > Keith Sibbert
    at
    today
    configuration.
    to a
    uninstalled
    no
    (and
    reinstall).
    ideas
    > > Thanks!
    > > Chapman Huffman
    Re:
    Chapman,
    I am beginning to think that the 750C driver you added may have placed a bad
    file on the system that is being used by another printer as well. You might try
    using the system file checker in Win98 to see if there is something that was
    changed when you installed this driver that might be affecting this. Float
    errors are generally driver related. If you can't find anything that way, you
    may want to try to reinstall your other printers with updated drivers or just
    remove them and reinstall in hopes this will overwrite the problem file. I don't
    think a reinstallation of AutoCAD LT 98 will help but if all else fails you can
    certainly try it. I would suggest you completely delete the AutoCAD LT 98 folder
    (after moving any needed drawing files to a different set of folders) prior to
    reinstalling.
    Keith Sibbert
    > > Chapman,
    > > Keith Sibbert
    > at
    > today
    > configuration.
    > to a
    > uninstalled
    > no
    > (and
    > reinstall).
    > ideas
    > > > Thanks!
    > > > Chapman Huffman
    *Huffman, Chapman
    Re:
    I was thinking I'd be "smart" and get the latest driver for the 750C from HP
    and install it... all of our printers are HP's...i'll run the system file
    checker and see. Fingers crossed.
    message news:38060B77.E680A421@autodesk.com...
    > Chapman,
    bad
    might try
    was
    you
    just
    don't
    you can
    folder
    prior to
    > reinstalling.
    > Keith Sibbert
    float
    program.
    in
    > > > Chapman,
    ACLT5.OLD.
    > > > Keith Sibbert
    exception
    > > at
    this
    > > today
    > > configuration.
    plotter,
    > > to a
    > > uninstalled
    to
    > > no
    settings
    > > (and
    > > reinstall).
    > > ideas
    > > > > Thanks!
    > > > > Chapman Huffman
    Re:
    Latest driver might fix it too.
    Keith Sibbert
    > > Chapman,
    > bad
    > might try
    > was
    > you
    > just
    > don't
    > you can
    > folder
    > prior to
    > > reinstalling.
    > > Keith Sibbert
    > float
    > program.
    > in
    > > > > Chapman,
    > ACLT5.OLD.
    > > > > Keith Sibbert
    > exception
    > > > at
    > this
    > > > today
    > > > configuration.
    > plotter,
    > > > to a
    > > > uninstalled
    > to
    > > > no
    > settings
    > > > (and
    > > > reinstall).
    > > > ideas
    > > > > > Thanks!
    > > > > > Chapman Huffman
