• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    LIITcom
    Fatal Error message when plotting to PDF
    968 Views, 7 Replies
    02-02-2012 01:18 AM
    A user is having issues with plotting from AutoCAD LT, when trying attempting a normal plot to PDF the program crashes and he is forced to close it, also when changing the way he plots to plot to DWG PDF it starts to work correctly but brings up a fatal error message as below and attached:
    FATAL ERROR: Unhandled Access Violation Writing 0x0014 Exception at 778e224dh
    Any help would be greatly appreciated.
    Thanks.
    Please use plain text.
    pendean
    Re: Fatal Error message when plotting to PDF
    02-02-2012 04:54 AM in reply to: LIITcom
    What version of LT?
    Did the problem suddenly start? Or has something changd with the user (new LT seat, new computer, removed something...)?
    And most importantly: is the problem in one file, ALL files, NEW files?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    LIITcom
    02-02-2012 05:10 AM in reply to: pendean
    What version of LT?
    I believe it is version 2007
    He has said it suddenly started
    Is within all files
    pendean
    02-02-2012 05:12 AM in reply to: LIITcom
    Windows Restore should reveal what changed between when it last worked and now.
    If no one else offers another sugggestion, explore the Autodesk recommended uninstall and reinstall procedures:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
    Try a simpler repair-reinstall first. Have your user backup first for easier recovery of any customizations.
    Active Member
    08-09-2012 09:13 PM in reply to: pendean
    I am getting similar errors. I cannot plot to pdf, any drawing. I reinstalled windows and autocad and this repaired the problem temporarily and now it has inexplicably returned just today. FATAL ERROR: Unhandled c000000dh Exception at 237eb667h It goes like this: 1. Open any drawing. 2. Select any layout. 3. File > Plot > Select PDF as printer/plotter 4. Click OK 5. Plot job progress bar appears 6. Fatal Error Message 7. Total crash, AutoCAD closes Please help. I cannot do my job without it.
    pendean
    08-10-2012 05:20 AM in reply to: 26111438
    >>>... this repaired the problem temporarily and now it has inexplicably returned...<<<
    Software has no parts that break: something got added or deleted to your system that changed it. Windows Restore is a good start, turning off automatic Windows Updates and any other automated software chages may work.
    Your issue is not LT related sadly, it's just the 'victim' of what is changing. Find out what that is.
    Charles_Shade
    08-10-2012 05:23 AM in reply to: pendean
    .NET update perhaps?
    When you look at the Restore calendar of events.
    You stated in the other thread that you had moved from LT 2008 to LT 2013.
    Was there a hardware change as well?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Member
    08-13-2012 09:56 PM in reply to: Charles_Shade
    Whatever the reason, it seems my file name was too long.  Over 17 characters seems to cause problems.  I shortened the file name(s) and can get the results I need now.
