AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: FATAL ERROR: Unhandled c0000409h: Exception at dcf51030h
- Highlight
- Email to a Friend
- Report Inappropriate Content
I did not clean registry values. I was not aware that removing the program wouldn't remove registry values. Could you provide some information on how to do this without screwing up my OS?
I am on a laptop, but not an underpowered one. I should have no problem running the aero theme, but I will try it as my options for troubleshooting seem to be running out.
- Highlight
- Email to a Friend
This is old but still applcable with the corrected version numbers, Autodesk recommended uninstall and reinstall procedures:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Also change LT2013's Hardware Acceleration setting from whatever you have currently, see if that helps.
- Highlight
- Email to a Friend
Just an update: I changed to a non-aero theme and the error changed to:
FATAL ERROR: Unahandled c0000409h Exception at e2b91030h
- Highlight
- Email to a Friend
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: FATAL ERROR: Unhandled c0000409h: Exception at dcf51030h
- Highlight
- Email to a Friend
yes,
I updated my video driver after this started happening.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
I want to refresh this case.
I have this kind of problem when I try to print sth from AutoCAD 2007 and AC 2008 on another machine.
I always get this kind of communicate:
FATAL ERROR: Unhandled c0000409h Exception at 3300e012h - AC 2007
FATAL ERROR: Unhandled c0000409h Exception at 675ddaf2h - AC 2008
Do you have any idea what can be a solution?
- Highlight
- Email to a Friend
The error messages mean little, sorry.
What changed recently on the PCs where the two versions are installed: new drivers for the printers, new printers, new server where the printers are accessed? New Windows or new PCs? Please try and find out what changed and report it.
- Highlight
- Email to a Friend
I'm not sure that you understand me correctly.
I have AutoCAD 2007 since 5 years on one computer and AC 2008 on another computer.
Previous all was ok. Now I have this kind of problem.
- Highlight
- Email to a Friend
Windows updates?
.NET updates?
Look at the System Restore log and see if something has been updated on your system.
As has been asked: What changed?
It worked for five years so why not now?
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
