AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
FATAL ERROR: Unhandled c0000409h: Exception at dcf51030h
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have just recently started to have a problem when opening files with xref'd aerials it gives the error:
and closes the program.
Any help would be appreciated!
Running:
Windows 7
AutoCAD 2013 LT
I7 720QM processor
4 gigs of ram
NVidia Geoforce GTS 360M 1 gb
Re: FATAL ERROR: Unhandled c0000409h: Exception at dcf51030h
- Highlight
- Email to a Friend
Additional notes:
I also have a working license for AutoCAD 2012 LT on my machine and it is seemingly handling the same files that causes AutoCAD 2013 LT to crash.
- Highlight
- Email to a Friend
Open the Files with RECOVER instead of open in LT 2013.
or
Try detaching the XREF using the LT 2012 seat and then reopening the File in the 2013 seat.
Reattach the XREF's
Any better?
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
- Highlight
- Email to a Friend
These files are coming from my CAD station in the office which has a seat of 2013 Civil 3d. He is attaching all imagines, etc. If he detaches all of the xrefs (or if I detach in 2012) I can open with my seat in 2013 LT fine.
We have tested this across multiple files with no success. This just popped up today.
- Highlight
- Email to a Friend
Have you looked at what has changed on the Computer since presumably yesterday?
Windows update? Registry Cleaner? Anti-Virus? Program added?
If ti was good yesterday and not today that usually indicates some change on the Computer has been made.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Charles makes a good point. If it did work in the past, you might consider a system restore back to when it worked. It's possible a Windows update to your .NET Framework or other prerequisite could have occurred and caused this issue.
You might also consider a repair install of 2013.
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: FATAL ERROR: Unhandled c0000409h: Exception at dcf51030h
- Highlight
- Email to a Friend
I have:
- Run the Autodesk Repair tool for 2013 LT
- Repaired the .net framework 4.0
- Used the .net framework removal tool
- Reinstalled the .net framework 4.0 client
So far, no change in the error.
Any further troubleshooting would be welcome.
- Highlight
- Email to a Friend
Oh and I uninstall and reinstalled AutoCAD 2013LT
- Highlight
- Email to a Friend
Did you clean out the Windows Registry of all Autodesk references when you uninstalled LT (and use a Windows Registry Cleaner to boot)? That's the best way to uninstall any program: restarting Windows then reinstalling is required afterwards.
Are you on a laptop? Turn off Win7's AERO Theme (and use Windows Basic theme): looks like WindowsXP and seems to help those with laptops the most.
