• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Error Message in AutoCAD LT 2012
    1109 Views, 8 Replies
    04-28-2011 01:23 PM
    I just downloaded, from subscription the latest AutoCAD LT 2012.  When working in a viewport, which has some layers frozen in the viewport, I tried to save my file and received the following error:
    "The object cannot be resolved or value limit has been exceeded.
    Inconsistent associative objects may display geometry and grips incorrectly and update in unexpected ways when edited.  You can undo to restore the associative object to its previous state."
    Does anyone have any idea what this means?  Can you please translate into ENGLISH.
    I was creating a boundary from an existing polyline in the drawing.  If you draw a rectangle, then say you want the same rectangle inside this one with an offset of 4" on the top, bottom and right side and 6" offset on the left.  Once I had this drawing done, I tried to save the file and it gave me this error.
    As I was not very far into the drawing from my previous save, I thought I would just exit AutoCAD and see if when I went back in I could continue, however, when I went back into the drawing it lost all of my associative dimensioning on the project I am working on.  45 minutes of updating ALL dimensions in the drawing, and now I have the exact same problem.
    ARGH!!! I truly wish Autodesk would try out the "New" products before releasing them.  I have not even had it installed for 24 hours and already there are glitches.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Error Message in AutoCAD LT 2012
    04-28-2011 02:20 PM in reply to: DANMIDDLETON7863
    >>>...I was creating a boundary from an existing polyline in the drawing....<<<
    So if you did this in another file, or a new file, the same thing happens? Or is the problem one file? I cannot replicate but I don't have your original file.
    Just staring at your error message: are you creating associative hatches?
    Do you have SAVEFIDELITY variable turned on, but set SAVE to something lower than 2010 format?
    >>>... I truly wish Autodesk would try out the "New" products before releasing them...<<<
    You can always join and participate in the real-world testing of anything coming out in the future: http://beta.autodesk.com and influence the next one with active involvement.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    04-29-2011 10:15 AM in reply to: DANMIDDLETON7863
    Sorry, not meant as a "dig" it is just very frustrating. I did sign up for the BETA testing link that you sent, so Thank You.  I am more than willing to help out when I can.
    More on my error message:
    I had to do a complete redraw on a number of objects.  I also had this annoying error prevent me from saving my file.  When you first open your drawing, and it gives me the same error, there is NOTHING TO UNDO so I am not sure what the error is telling me to do.  I purged the file 3 times, used the new delete duplicate objects and typed in "all" when it asked me to select objects.  I then purged again, and it now allows me to save without giving me this error.
    I would really appreciate any feedback.
    New Member
    11-04-2011 06:05 AM in reply to: DANMIDDLETON7863
    Have the same problem with AutoCAD 2012 when opening or saving a file
    Simple 2D drawing, 64 layers, No blocks, purged drawing, did an audit of drawing - nothing helped.
    Moved file to local machine drive - same issue.
    Reviewed layer name for any unusual characters - nothing
    Solution:
    Drawing had all but 1 layer locked.
    Unlocked all layers, saved drawing, closed drawing
    Opened - no error
    Locked all but 1 layer, saved file, closed file, opened file - ERROR
    *Expert Elite*
    pendean
    11-04-2011 06:07 AM in reply to: dan.rohrbach
    Post the DWG file, that's unusual.
    Distinguished Contributor
    11-22-2011 04:56 PM in reply to: dan.rohrbach
    same thing just happened to me. found this post, yup i had locked layers, i unlocked them, fixed. lock them again and i get the error when opening the file. havent seen this before... interesting...
    Active Member
    neuve
    12-12-2011 04:12 AM in reply to: DANMIDDLETON7863
    Got the same message when finishing editing some closed polylines and some hatches associated to them. Never could undo.
    My solution: Isolate problematic entities, explode, delete hatches, flatten polylines (I know, I tried to draw on 2d but im drawing over another which I cant assure is completely 2D), join lines, close polylines and create hatches again.
    Hope this helps
    Member
    05-07-2012 05:18 AM in reply to: DANMIDDLETON7863
    Hi Dear sir,
     I did wat u r telling n did  all locked layer in unlock but its still lik ds only.Same error coming. So wat i hav to do. I did all thing purg audit lock all layers n unlock too. But i dont know one layer is showing lock but wenever i m seeing in layers its not. So wat should i hav to do.
    10-05-2012 07:16 AM in reply to: dan.rohrbach
    thanks Dan!!, that's what was happening to me.
