• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    Accepted Solution
    Enhanced attribute editor by defaut, how to change it ?
    809 Views, 1 Replies
    10-11-2012 05:53 AM
    Hi, By defaut a double click on a attribute opens the "enhanced" fonction. I don't want this, I want the "normal" attribute editor, is there a variable to change ? Or another way ? Thanks.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Enhanced attribute editor by defaut, how to change it ?
    10-11-2012 09:46 AM in reply to: c.dufrene
    Do you mean you want DDEDIT command instead of BATTMAN command?
    CUI command's pop-up stores all the double-click actions: change the default under ATTRIBUTE BLOCK and ATTRIBUTE DYNAMIC BLOCK from EATTEDIT command to DDEDIT command. You do this by deleting the definition at each location and replacing it from the list below.
    Just be aware of what you are giving up in the process as far as features go.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
