AutoCAD LT
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Dimensions not visible in layout view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is one of those on-again off-again frustrating issues.
The problem: I add a dimension in Model Space, but it is not visible in Layout. No problem with drawing items, only dimensions. After some "floundering" (not an official AutoDesk term), I see the dimension in Layout. Don't know what I'm doing wrong, or how I manage to get the dimensions to show again. Any and all help appreciated.
Yes, have searched the help file and manuals to no avail.
Bill
LT 2011
Windows XP
Re: Dimensions not visible in layout view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
New information:
It seems to be a problem with a new layer I made, "Dimensions", anything I add in Model space on this new layer does not appear on the Layout tab. All settings on new layer are same as layer 0, where there is no problem viewing objects on Layout tab.
Gotta be doing something wrong!
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the settings for the new layer are the same as for layer 0 which is visible in your layout viewports (all on, all thawed) then this doesn't seem to be a problem with the layer. Is the current dimension style annotative by any chance when you are adding these dimensions? Try typing ANNOALLVISIBLE at the command prompt, hit enter and change the setting to 1. Can you see the dimensions now?
PS. By suggesting reading manuals and the help file I didn't mean you will never come accross problems you will not be able to get over by yourself once you've gone through the books. I only suggested a good way to start off. Nothing mean. Honestly.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Make the Layout active by double clikcing inside of it.
Type LA at the Command line.
Is the Layer Thawed in the Viewport?
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OP are you trying to do something with annotative dimensions? If so, then is your modelspace CANNOSCALE set to match your paperspace viewport?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks everybody -
Tried all you suggest; cannoscale is OK, annotative is OK, and layer properties appear same.
I may be asking alot, but if you care to view the file, it is attached. In model space I have entered two dimensions, one on layer "0", the other on layer "Dims". Text and dimension appear in layout view for layer "0" but not layer "Dims".
Appreciate all your help.
Bill
Olympia WA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OOPS!
Charles, I had not tried your suggestion yet:
"Make the Layout active by double clicking inside of it. Type LA at the Command line. Is the Layer Thawed in the Viewport?"
No, it was not thawed in the viewport - when I thawed the layer, the dimensions became visible in Layout!
Honestly, I had no idea a layer could be thawed in model space and NOT thawed in the viewport.
Again, I sincerely appreciate everyone's help.
Bill
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Glad that worked for you.
If you started with a Template open the Template and check that same Layout and Thaw the Layer.
Please mark any response as "Accept as Solution" if it answers your question.
__________________________________________________
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am unsure as to whether or not you have fixed this issue but I had the same problem and I fixed mine by the "Annotative Visability" button located on the bottom right of your screen.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Mark...
Well, yes I think I resolved the issue, but always can use another perspective.
Bill
