• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    FLHX
    Different View Description?
    78 Views, 1 Replies
    10-10-2012 08:57 AM
    Not sure exactly how to describe what I'm looking for.  The best way I can describe what I want is as follows:
    Some of my drawings have a reference to another view, say "View A". View A itself might be enlarged, or show more detail or whatever.
    I want to find an easy way to construct the designator for View A.  That is, the little part on the main drawing that tells us that there IS a View A.
    Specifcially, I'm looking for what I can clumsily describe as follows:
    "A circle drawn around that section of the drawing that's being referred to in View A, with the letter A inserted into the diameter, with arrows at both ends pointing towards the A".
    If I could find an example I'd include it, but I'm hoping someone here will know what I'm referring to and tell me whether ACADLT 2011 can easily produce it.  I can draw it manually if need be, but I was hoping the software can make it easy.
    Bueller???
    Bueller???
    Please use plain text.
    pendean
    Re: Different View Description?
    10-10-2012 09:01 AM in reply to: FLHX
    You'd have to draw something (on a no-plot layer) to provide you with that type of information: nothing built-in beyond the small preview you can see in VIEW command's pop-up when you select one.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
