• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    tjr226
    Creating a page setup to use every time
    487 Views, 4 Replies
    01-11-2011 07:13 AM
    It looks like this is a challenging problem, but I hope someone can help me with it. I receive many DWG and DXF files that I have to print off, and so far I haven't found a way to automatically select the options I want to. There might be something I can do in the templates in AppData, but that isn't clear yet.
    Is there any way to access the 'Model' template and change the settings to what I want?
    Please use plain text.
    Charles_Shade
    Re: Creating a page setup to use every time
    01-11-2011 09:19 AM in reply to: tjr226
    Click Open as you would for any file.
    At the bottom change File Type to DWT.
    This should open your Template Folder and the Templates to change will be there.
    If not then do a search for files of type *.dwt
    Also - If you have a template that you want and are receiving files that do not have the plot settings you need then right click a Layout Tab and Import the Layout from the Template that you tweaked above. You will need to look at manipulating Viewports if they are not consistent.
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Charles_Shade
    01-11-2011 09:21 AM in reply to: tjr226
    You could also create a Menu Macro that goes thru your required Plot Settings without having to type them each time if all you need to do is plot the file to: Your Printer, D size paper, 1/4" Scale, Landscape, etc...
    pendean
    01-11-2011 10:45 AM in reply to: tjr226
    What LT version do you use? PUBLISH may be yet another option to try in addition to the comments above.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    tjr226
    01-11-2011 11:03 AM in reply to: pendean
    Thanks for the suggestions, looking for the macro function led me to the answer.
    I ended up going into Tools-Options-Plot & Publish, where there was a box to check to use the last successful print settings automatically. Before, it was going to a default device. It will be very useful since we use the same settings for every plot.
