• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Member
    Crashing Autocad LT2010 and 2011
    338 Views, 8 Replies
    04-22-2010 02:40 AM
    Has anyone had the problem when printing pdfs then when closing the drawing it crashes?
    I have had this problem for LT2010 and LT2011?
    Running windows 7 64Bit
    Cheers
    Michael
    Please use plain text.
    *Dean Saadallah
    Re: Crashing Autocad LT2010 and 2011
    04-22-2010 04:54 AM in reply to: MichaelGibson5012
    What PDF driver are you using?
    Are both programs on the same PC? If yes, did you "migrate" when installing
    2011?
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Active Member
    04-22-2010 05:13 AM in reply to: MichaelGibson5012
    Yes both installations were on the same computer, only have the LT2011 and I did migrate the settings.
    Also having fatal errors on a few other computers with LT2011? all with the settings migrated!!
    Is it better not to migrate the settings?
    Cheers
    Michael
    *Dean Saadallah
    04-22-2010 05:26 AM in reply to: MichaelGibson5012
    Yes, migration is the problem: you had a problem in 2010, and by migrating,
    you took it along with you to 2011.
    Backup all of your files, and all of your customizations for both programs.
    Follow Autodesk's Uninstall AutoCAD instructions:
    http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10243968&linkID=9240617
    Dean Saadallah
    Active Member
    04-22-2010 05:49 AM in reply to: MichaelGibson5012
    Thanks will try that and will let you know how I get on :smileyhappy:
    Cheers
    Michael
    *Dean Saadallah
    04-22-2010 06:09 AM in reply to: MichaelGibson5012
    Don't do anything if you have a deadline coming up :smileyhappy:
    Dean Saadallah
    Active Member
    04-26-2010 01:13 AM in reply to: MichaelGibson5012
    Dean,
    The link you put in your previous message does not work
    Michael
    *Dean Saadallah
    04-26-2010 05:02 AM in reply to: MichaelGibson5012
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
    Dean Saadallah
    Active Member
    04-27-2010 01:03 AM in reply to: MichaelGibson5012
    Michael
