• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    Crash on open
    154 Views, 9 Replies
    03-13-2013 12:52 PM
    When I try to open this file I get an immediate crash. I have tried to recover the drawing and the results are the same.
    Please use plain text.
    Distinguished Contributor
    Nik-D
    Re: Crash on open
    03-13-2013 12:55 PM in reply to: Crass
    Can you post the file here so we can look at it?
    *Expert Elite*
    pendean
    Re: Crash on open
    03-13-2013 02:04 PM in reply to: Crass
    Is the problem one file? If yes, move it to your local PC's harddrive and try using RECOVER command to open it.
    or is it ALL files?
    Source of the file (what program created it, how was it delivered, is this the first time you open it)?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    Re: Crash on open
    03-13-2013 02:55 PM in reply to: pendean
    The file was created by us in ACAD LT 2011. There are about eight different XREFs attached all created by ACAD or ACAD Civil3D - Some created by us and some by other companies. I am not sure which file is the problem and since I cannot even open the file, it's difficult to troubleshoot.
    Nik-D
    Re: Crash on open
    03-13-2013 04:08 PM in reply to: Crass
    Move the XREF's to a different folder so that they cannot be found when AutoCAD tries to load the drawing. See if that has any effect.
    Try the RECOVERALL command.
    Also you said that there is an immediate crash, what exactly happens? do you get any command line info, does the program just quit, freeze?
    *Expert Elite*
    Charles_Shade
    Re: Crash on open
    03-13-2013 06:50 PM in reply to: Crass
    Do you have a BAK file or autosave file from when it was first created?
    If so it may be worth looking at that prior to the attachment of any XREF's or other vertical content.
    Does your LT have the Object Enabler loaded for its version?
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15131158&linkID=9240818
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Valued Contributor
    Re: Crash on open
    03-14-2013 08:15 AM in reply to: Nik-D
    I am not sure how to use the RECOVERALL command since the program crashes while loading the XREFs. Therefore I cannot even use a command, hence immediate (during load). I will try to move the xrefs one at a time to see if that does anything.
    Nik-D
    Re: Crash on open
    03-14-2013 09:58 AM in reply to: Crass
    Open AutoCAD LT, open a new drawing. then:
    Click the AutoCAD symbol (very top left)
    Click drawing utilities
    Click Recover
    Click Recover with XREFS.
    For some reason the recover with XREFs option is only available if you have a drawing open already
    HTH
    *Expert Elite*
    Charles_Shade
    Re: Crash on open
    03-14-2013 10:30 AM in reply to: Crass
    If the Drawing crashes while loading the XREF's it's time to go and run Recover on the Drawing files that are the XREF's before opening the drawing they are bing XREF'ed into.
    Eliminate possible problems at the source.
    Valued Contributor
    Re: Crash on open
    03-15-2013 03:07 PM in reply to: Charles_Shade
    Thanks for the help all. I needed to move onto something else so have not been able to dedicate much time to troubleshooting this issue but, the update is:
    1. I installed the AutoCAD Civil 2011 Object Enabler;
    2. A co-worker, who is able to open the file without problems on ACAD LT 2013, opened and purged the problem drawing; and
    3. I tried the RECOVERALL command
    Same result. It crashes immediately on open or in the case of #3 as the RECOVERALL command is running.
    I will do as you recommend Charles and try to recover all the XREFs individually. The problem I have with this method is that how would I know what the XREFs are since I cannot even open the problem dwg? Luckily my co-worker can open the dwg and indentify them for me. Otherwise I would be screwed.
    Have a great weekend. I will get back to this on Monday. Thanks!
