• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    Change Case
    179 Views, 3 Replies
    04-19-2011 02:26 PM
    I just finished a set of drawings and now the boss wants them to be in lower case format...our standard is upper case but whatever.
    Is there a way to do mulitple lines of text at once?  I know i can click on one text box and highlight the text and do it...I was just hoping that I could do it drawing wide.
    Autocad LT2011
    Please use plain text.
    pendean
    Re: Change Case
    04-19-2011 02:29 PM in reply to: arkman
    If it is all MTEXT, and not plain TEXT, trhen yes: double-click each MTEXT column, select all, and right-click (choice is there to what many case option).
    If it is all single lines of Text, sadly you need full AutoCAD and some additional customized routines to finish the task.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    AlistairBean1906
    Re: Change Case
    04-20-2011 07:40 AM in reply to: pendean
    In addition to Deans first line, if you are editing a piece of MText then try CTRL + A to select all and CTRL + SHIFT + L to set it to lower case.
    This can be quicker for a more repetive task like this
    Active Contributor
    Re: Change Case
    04-20-2011 02:18 PM in reply to: arkman
    Thanks guys.  I guess I wasn't clear.  I know the way to do each mtext at a time.  I was hoping to do it through out the drawing all in one shot.
