AutoCAD LT
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot draw, select or enter commands in AutoCAD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got a user who uses AutoCAD 2013 LT. He is not able to draw lines, type commands, select objects etc, in new and in existing documents (that other users can edit). I have reset the default settings and did a reinstall of AutoCAD through a package. This did not resolve it. He also does not get the "crosshair" you normally see when using AutoCAD.
Please advise.
Re: Cannot draw, select or enter commands in AutoCAD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there anything the user can do other than open a DWG file?
If not time for a more aggressive repair.
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?li
Also the program REVO UNINSTALLER (Free) will do a better job in removing Programs than Windows uninstall.
Please mark any response as "Accept as Solution" if it answers your question.
__________________________________________________
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have seen this myself. The mouse is a regular mouse. clicking buttons work, the command is even visible on the bottom. I'm not able to type in any commands, select objects or place a line in an image. Other users are able to do this. normally there is a sort of crosshair visible when editing images.I have seen this crosshair on other machines that come with the same OS and AutoCAD installation (OS is done by imaging, AutoCAD by package)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes the user is using Windows 7 Enterprise 64 bit. I changed the Aero theme to Windows Basic theme. I'm not able to type any commands in LT2013. That option is not working.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
..and plug the mouse and keyboard back in while you're at it! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same thing just happened to me in AutoCAD 2012. Mouse and keyboard works fine in AutoCAD menus and all other programs, but not in the graphical area of AutoCAD, I cannot enter a command except for [spacebar}/enter nor mark, select, left or right click with the mouse. Everything worked fine two days ago but when I started up today this situation appears.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
