AutoCAD LT
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Blocks and attributes
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So if you close and open the attached drawing the Attribs move on you?
Two questions:
1. When you open this Block in the Block Editor are you then Inserting the Block again or are you just expecting the change to show up?
2. If when you have changed the Attribs in the BE are you then running ATTSYNC on the block in Paperspace to update the Attribs in the block?
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
May I ask why did you post an exploded titleblock in this last drawing? Is that what you are doing, exploding the block to edit the content?
That explains why you think you cannot edit your block that I posted back, you are not using ATTEDIT or EATTEDIT commands perhaps which are designed to edit attributes inside unexploded blocks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes you are correct every time i close and open the drawings with the block the bottom three attributes move and each time they move a little more each time in the same directions. I have tried every sunniro to insert the attributes and the last three keep moving. When I go into the block editor and move again back where i want them. but when i close the block editor the never moved back in the drawing.
as for your question numbered Two in all the research i did to try to figure this out i never saw the "AttributeSYNC" please enlighten me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i exploded the block to move the attribute where i wanted them to be in the location where they are to sit. if i block edit them they dont move when i get back to the drawing. I have learned very well how the Atteditors work. lots of pratice the last few days.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I will give this a try. but I am going to start from scratch so not to bring in any corupt parts from old files. I will keep you posted
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Alright I have tried the not locking the attributes I am Still having the same problems, I am attaching two drawings first drawing where I tried to produce the block the the first drawing backup file so that you can see the changes with saving and reopening.
Any help is appreciated, I'm stomped.
